Archicad C++ API
Archicad 29 - How to query interface mode (light / dark)
J_Studanski
Heya,
With the introduction of dark mode on macOS—how can we query if the CAD is in light or dark mode so we can adjust icons, for example? I didn't find any info about that so far, and also no new API function that sounded like it could serve this purpose.
Is it even possible to reload a plugin UI or a different set of icons for it at runtime when the CAD switches from dark to light mode or vice versa?
Johann
AppearanceManager::GetMode() will tell you if it's dark/light mode.
The API will build 2 sets of icons (light/dark) and switch between them for you - no need for extra code.
Text colour also dynamically changes to suit dark/light mode - so very little required on your part.
Ralph Wessel BArch
Central Innovation
Ralph Wessel BArch
Central Innovation
Thank you!
We do have our own icons for our toolbar—a handcrafted set for light and dark themes, and we compiler our own resources, so no auto-switching of icons takes place. But I already implemented a way for us to support both themes.
Do you also know if we get some kind of event when the user switches the mode during runtime? I see there's an event class next to it. Or can Archicad only switch its own mode with a restart of the application?
