Archicad C++ API
Archicad crashes after closing dialog box
I've got working code for retrieving and displaying the amount of unique operators and targets of SEOs within a project. This works fine until I close the dialog box, and Archicad crashes. I've debugged and this is the error Visual Studio gave me:
Exception thrown at 0x000000000033203A in Archicad.exe: 0xC0000005: Access violation executing location 0x000000000033203A. occurred
Here's the code for getting the operators:
static int GetNumberOfOperators() {
	int size = 0;
	GSErrCode err = NoError;
	GS::Array<API_Guid>	allElements;
	GS::Array<GS::UniString> currentOperators;
	ACAPI_Element_GetElemList(API_ZombieElemID, &allElements);
	for (const API_Guid& guid : allElements) {
		GS::Array<GS::UniString> allOperators;
		API_Guid** guid_Operators = nullptr;
		Int32 nLinks;
		bool insert = true;
		err = ACAPI_Element_SolidLink_GetOperators(guid, &guid_Operators, &nLinks);
		if (err != NoError)
			continue;
		for (int i = 0; i < nLinks; i++) {
			GS::Guid nGuid = APIGuid2GSGuid(guid_Operators[0]);
			GS::UniString sGuid = nGuid.ToUniString();
			for (USize a = 0; a < currentOperators.GetSize(); a++) {
				if (sGuid == currentOperators)
					insert = false;
			if (insert) {
				allOperators.Insert(i, sGuid);
				currentOperators...
The code for getting targets is pretty much exactly the same except for getting targets instead of operators.
Any help with this would be gratefully received.
Thanks
8 REPLIES 8
Akos Somorjai
This is the correct line:
GS::Guid nGuid = APIGuid2GSGuid((*guid_Operators));
Best, Akos
Akos Somorjai
Best, Akos
Sorry, bbcode tricked me:
Thanks for the reply, although unfortunately this didn't fix my issue. Is there anything else that could be the cause of the crash?
Thanks
Akos Somorjai
Then I guess the problem is not in this function. Could you please send me the bug ID from GSReport?
Thanks, Akos
P.S.: you can use a GS::HashSet instead of the GS::Array, then you don't have to check if the guid is already in there.
Here's the bug ID:
AC21-2019-07-26-09-42-25-4517
Also, thanks for the suggestion to use GS::HashSet.
Cheers
Akos Somorjai
Thanks!
It hasn't showed up in our crash report database yet; did you send it in?
Best, Akos
I've tried sending it again:
AC21-2019-07-30-11-04-47-2331
Cheers
EDIT: I've managed to solve the problem, as I was looking at the entirely wrong function. My output function had a memory error which was causing the problem. Thanks for the assistance anyway.
Akos Somorjai
This crash happens when your add-on is being unloaded, and its coming from your add-on. Maybe you free something twice?
SEO_Counter_Export.apx + 19243
C0000005 ACCESS_VIOLATION reading location 0xffffffffffffffff
Best, Akos
