ā2011-01-12
05:43 AM
ā2023-08-03
10:30 AM
Doreena Deng
GSErrCode __ACENV_CALL Initialize (void)
GSErrCode err = ACAPI_Install_MenuHandler (32500, MenuCommandHandler);
if (err != NoError)
DBPrintf ("LibPart Test:: Initialize() ACAPI_Install_MenuHandler failed\n");
IO::Location rab("E:/ArchiCAD Phase/Present ArchiCAD/Phase_9 16 ąø.ąø¢. - 31 ąø.ąø. 53/All HRC OK/HRC_Object/");
ACAPI_Environment (APIEnv_AddLibrariesID, reinterpret_cast<void *>(&rab), NULL);
return NoError;
} // Initialize
CHANSI2Unicode("ą¹ąøą¹ąø”ąø«ąøą¹ąø«ąø„ąøµą¹ąø¢ąø”ąøąø„ąø§ąø 15cm ยาว 3 ą¹ąø”ąøąø£.gsm", strlen("ą¹ąøą¹ąø”ąø«ąøą¹ąø«ąø„ąøµą¹ąø¢ąø”ąøąø„ąø§ąø 15cm ยาว 3 ą¹ąø”ąøąø£.gsm"), part.file_UName, API_UniLongNameLen);
if((err = ACAPI_LibPart_Search(&part, false)) == NoError)
And it return no errorā2011-01-12 05:45 AM
ā2011-01-12 05:46 AM
ā2011-01-12 05:48 AM
ā2011-01-12 10:10 AM
Paodekcal wrote:I don't fully understand what you are trying to do. I assume you want to be sure a specific library is loaded when your add-on carries out its primary function. I have 2 suggestions:
Do you have any idea? to fix code to work correctly at picture 2 That I don't want to run Libpart Function before.
ā2011-01-12 10:25 AM
ā2011-01-12 10:29 AM
Paodekcal wrote:OK. I suggest using
I want to "Auto Link my folder library every time I create new project or open ArchiCAD"
So the users don't have to link library folder by themself.
Like the roofmaker or truss maker
ā2011-01-12 10:45 AM
ā2011-01-12 10:54 AM
it may be called before a project has been opened.Thank you.
