2021-01-05
10:22 AM
- last edited on
2021-09-14
01:35 PM
by
Noemi Balogh
2021-01-07 06:48 AM
void Test_CreateDrawing()
API_NavigatorItem item;
// Gets view with id "TEST" and name "TEST"
TEST_Navigator(item);
API_Element elem;
BNZeroMemory(&elem, sizeof(elem));
elem.drawing.head.typeID = API_DrawingID;
GSErrCode err = ACAPI_Element_GetDefaults(&elem, NULL);
elem.header.layer = ARCHICAD_LAYER; //set to Archicad Layer
elem.drawing.drawingGuid = item.guid;
elem.drawing.isCutWithFrame = true;
elem.drawing.ratio = 1;
elem.drawing.angle = 0;
elem.drawing.colorMode = APIColorMode_OriginalColors;
elem.drawing.penTableUsageMode = APIPenTableUsageMode_UseOwnPenTable;
elem.drawing.useOwnOrigoAsAnchor = false;
elem.drawing.manualUpdate = false;
// set name
elem.drawing.nameType = APIName_CustomName;
sprintf(elem.drawing.name, "TEST");
// coords (hotspot pos)
elem.drawing.pos.x = 0.427592;
elem.drawing.pos.y = 0.271358;
// set anchor point to middle node
// ~~ MAIN ISSUE: this is not applied and reverts to APIAnc_LB ~~
elem.drawing.anchorPoint = APIAnc_MM;
// Create drawing
ACAPI_CallUndoableCommand("Create Layout Drawing", [&] () -> GSErrCode { //
err = ACAPI_Element_Create(&elem, NULL);
return NoError; });
if (err != NoError)
WriteReport("[" __FUNC__ "] ERROR %s - ACAPI_Element_Create", ErrId2Name(err));
return;
// get drawing to check value
if (ACAPI_Element_Get(&elem) == NoError)
// prints out anchor point, prints 6 (LB) not 4 (MM)
WriteReport("elem.drawing.anchorPoint: %d", elem.drawing.anchorPoint);
// Try to change anchor point again
API_Element mask;
ACAPI_ELEMENT_MASK_CLEAR(mask);
ACAPI_ELEMENT_MASK_SET(mask, API_DrawingType, anchorPoint);
ACAPI_CallUndoableCommand("Update Drawing", [&]() -> GSErrCode { //
err = ACAPI_Element_Change(&elem, &mask, NULL, NULL, true);
return NoError; });
if (err != NoError)
WriteReport("[" __FUNC__ "] ERROR %s - ACAPI_Element_Change", ErrId2Name(err));
return;
// get drawing for the 2nd time then print anchor, still prints 6
