Change/modify dimension
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2021-01-08
06:32 AM
- last edited on
2021-09-14
01:35 PM
by
Noemi Balogh
2021-01-08
06:32 AM
I've created a simple code that will read all the API_DimElem from memo then combine consecutive equidistant dimensions (dimVal). Then use ACAPI_Element_Change() to update the element but it returns API_BADPARS.
/***** code for creating newDimElems here *****/ // change/update element dimCnt = newDimElems.GetSize(); memo.dimElems = (API_DimElem**)BMAllocateHandle(sizeof(API_DimElem) * dimCnt, ALLOCATE_CLEAR, 0); for (UInt32 i = 0; i < dimCnt; ++i) (*memo.dimElems) = newDimElems; API_Element mask; ACAPI_ELEMENT_MASK_CLEAR(mask); ACAPI_ELEMENT_MASK_SET(mask, API_DimensionType, nDimElem); elem.dimension.nDimElem = dimCnt; err = ACAPI_Element_Change(&elem, &mask, &memo, APIMemoMask_All, true);Any idea where I go wrong?
~ReignBough~
ARCHICAD 27 INT (since AC18)
Windows 11 Pro, AMD Ryzen 7, 3.20GHz, 32.0GB RAM, 64-bit OS
Labels:
- Labels:
Add-On (C++)
1 REPLY 1
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-01-11 11:04 AM
2021-01-11
11:04 AM
UPDATE
Instead of creating dimensions then changing it, I just process the coordinates before creating the dimension. (As before, combining equal consecutive "computed" dimVal.)
But the the generated dimension is not as expected.
Raw dimensions <-- dimension is not yet created base.loc3D (0.00000000, 0.00000000, 0.00000000) pos3D (18.45889129, 30.99275442, 0.00000000) API_NoteContent_Measured 0.00000 base.loc3D (0.00000000, 0.00000000, 0.00000000) pos3D (20.12751369, 30.99275442, 12.00000000) API_NoteContent_Measured 0.00000 base.loc3D (0.00000000, 0.00000000, 0.00000000) pos3D (20.40751369, 30.99275442, 12.00000000) API_NoteContent_Measured 0.00000 --\ distance base.loc3D (0.00000000, 0.00000000, 0.00000000) pos3D (20.68751369, 30.99275442, 12.00000000) API_NoteContent_Measured 0.00000 | from base.loc3D (0.00000000, 0.00000000, 0.00000000) pos3D (20.96751369, 30.99275442, 12.00000000) API_NoteContent_Measured 0.00000 | previous base.loc3D (0.00000000, 0.00000000, 0.00000000) pos3D (21.24751369, 30.99275442, 12.00000000) API_NoteContent_Measured 0.00000 | dimElem base.loc3D (0.00000000, 0.00000000, 0.00000000) pos3D (21.52751369, 30.99275442, 12.00000000) API_NoteContent_Measured 0.00000 | is equal base.loc3D (0.00000000, 0.00000000, 0.00000000) pos3D (21.80751369, 30.99275442, 12.00000000) API_NoteContent_Measured 0.00000 | to 280 base.loc3D (0.00000000, 0.00000000, 0.00000000) pos3D (22.08751369, 30.99275442, 12.00000000) API_NoteContent_Measured 0.00000 | (equidistant) base.loc3D (0.00000000, 0.00000000, 0.00000000) pos3D (22.36751369, 30.99275442, 12.00000000) API_NoteContent_Measured 0.00000 --/ base.loc3D (0.00000000, 0.00000000, 0.00000000) pos3D (22.52751402, 29.79275442, 12.00000000) API_NoteContent_Measured 0.00000 base.loc3D (0.00000000, 0.00000000, 0.00000000) pos3D (23.72751369, 30.99275442, 12.00000000) API_NoteContent_Measured 0.00000 Filtered dimensions (newDimElems) <-- dimension is not yet created, this is the above after being processed base.loc3D (0.00000000, 0.00000000, 0.00000000) pos3D (18.45889129, 30.99275442, 0.00000000) API_NoteContent_Measured 0.00000 base.loc3D (0.00000000, 0.00000000, 0.00000000) pos3D (20.12751369, 30.99275442, 12.00000000) API_NoteContent_Measured 0.00000 base.loc3D (0.00000000, 0.00000000, 0.00000000) pos3D (22.36751369, 30.99275442, 12.00000000) API_NoteContent_Custom <MeasuredValue> 8 EQ PARTS base.loc3D (0.00000000, 0.00000000, 0.00000000) pos3D (22.52751402, 29.79275442, 12.00000000) API_NoteContent_Measured 0.00000 base.loc3D (0.00000000, 0.00000000, 0.00000000) pos3D (23.72751369, 30.99275442, 12.00000000) API_NoteContent_Measured 0.00000 Created dimensions base.loc3D (23.72751369, 30.99275442, 0.00000000) pos3D (0.00000000, 0.00000000, 0.00000000) API_NoteContent_Measured 0.00000 base.loc3D (22.52751402, 29.79275442, 0.00000000) pos3D (0.00000000, 0.00000000, 0.00000000) API_NoteContent_Measured 1.20000 base.loc3D (22.36751369, 30.99275442, 0.00000000) pos3D (0.00000000, 0.00000000, 0.00000000) API_NoteContent_Custom 160 8 EQ PARTS base.loc3D (20.12751369, 30.99275442, 0.00000000) pos3D (0.00000000, 0.00000000, 0.00000000) API_NoteContent_Measured 2.24000 base.loc3D (18.45889129, 30.99275442, 0.00000000) pos3D (0.00000000, 0.00000000, 0.00000000) API_NoteContent_Measured 1.66862
~ReignBough~
