Archicad C++ API
ButtonClicked function do not work.
Soonbum Jeong
Dear developers,
I finished writing UI resource code.
But event handle working has difficult now.
Next code is current working.
In the ButtonClicked function,
if (ev.GetSource () == &btn_OK) {
These codes are not working.
Could you answer me about the cause?
Environment : Windows 7 64Bit, ArchiCAD 19, API v19
class placeEuroformDialog :	public DG::ModalDialog,
							public DG::ButtonItemObserver,
							public DG::CompoundItemObserver
protected:
	enum Controls {
		ButtonID		= 1,
		GroupboxID		= 2,
		LeftTextID		= 3,
		IntEditID		= 4,
		PopupControlID	= 5
	DG::Button		btn_OK;
	DG::Button		btn_Cancel;
	DG::GroupBox	grp_placeCnt;
	DG::GroupBox	grp_euroformOptions;
	DG::LeftText	lbl_horCnt;
	DG::LeftText	lbl_verCnt;
	DG::LeftText	lbl_wid;
	DG::LeftText	lbl_hei;
	DG::LeftText	lbl_ori;
	DG::LeftText	lbl_inst;
	DG::IntEdit		edt_horCnt;
	DG::IntEdit		edt_verCnt;
	DG::PopUp		popup_wid;
	DG::PopUp		popup_hei;
	DG::PopUp		popup_ori;
	DG::PopUp		popup_inst;
	virtual void	ButtonClicked (const DG::ButtonClickEvent& ev) override;
public:
	placeEuroformDialog ();
	~placeEuroformDialog ();
placeEuroformDialog::placeEuroformDialog () :
		DG::ModalDialog		(ACAPI_GetOwnResModule (), 32600, ACAPI_GetOwnResModule ()),
		btn_OK				(GetReference (), ButtonID),
		btn_Cancel			(GetReference (), ButtonID),
		grp_placeCnt		(GetReference (), GroupboxID),
		grp_euroformOptions	(GetReference (), GroupboxID),
		lbl_horCnt			(GetReference (), LeftTextID),
		lbl_verCnt			(GetReference (), LeftTextID),
		lbl_wid				(GetReference (), LeftTextID),
		lbl_hei				(GetReference (), LeftTextID),
		lbl_ori				(GetReference (), LeftTextID),
		lbl_inst			(GetReference (), LeftTextID),
		edt_horCnt			(GetReference (), IntEditID),
		edt_verCnt			(GetReference (), IntEditID),
		popup_wid			(GetReference (), PopupControlID),
		popup_hei			(GetReference (), PopupControlID),
		popup_ori			(GetReference (), PopupControlID),
		popup_inst			(GetReference (), PopupControlID)
	AttachToAllItems (*this);
placeEuroformDialog::~placeEuroformDialog ()
	DetachFromAllItems (*this);
void placeEuroformDialog::ButtonClicked (const DG::ButtonClickEvent& ev)
	ACAPI_WriteReport ("This message is show.", true);
		ACAPI_WriteReport ("OK Button... This message is not show.", true);
		PostCloseRequest (Accept);
GSErrCode	placeEuroform (void)
	placeEuroformDialog	dialog;
	dialog.Invoke ();
	return NoError;
GSErrCode __ACENV_CALL	MenuCommandHandler (const API_MenuParams *menuParams)
	GSErrCode	err = NoError;
	switch (menuParams->menuItemRef.menuResID) {
		case 32500:
			switch (menuParams->menuItemRef.itemIndex) {
				case 1:		err = placeEuroform ();		break;
			break;
	return err;
}		// CommandHandler ()
Oleg
ButtonID		= 1,
Each control must have a unique number (ID) exactly equal to the position in the 'GDLG' resource.
Oleg
ButtonID		= 1,
Soonbum Jeong
Dear Oleg,
Your answer is exactly right.
My source code did not have "unique" ID.
After fixed code, my code works well.
Thank you, Oleg.
