Archicad C++ API
Can Archicad Education use add-in?
Thanh Phan
I have an Archicad Education license and am trying to test my custom add-in but it can't seem to load it. Is it because of my license or my add-on?
Anyone can develop an add-on that works in the demo version... the easiest way to learn.  For an add-on to work in any licensed version, the developer must be registered with Graphisoft and received a personal MDID to identify themselves within the add-on.  All of this is explained both in posts in this forum, and in the Archicad API documentation.  You can learn by compiling any of the many sample add-ons provided with the API dev kit... which will work in demo mode (without the MDID).
AC 28 USA and earlier   •   macOS Sequoia 15.2, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
One of the forum moderators
7 REPLIES 7
If you can load other add-ons with your Educational License (which I am pretty sure you can), but you can't load your add-on, then I would suspect a problem with the compilation of the add-on.
Don't ask me what though.
Can you give me a dumb add-in to test? It's hard to find an Archicad add-in on the internet. Thank you.
My add-in still works on demo version
Someone that develops add-ons will have to answer.
I think you have to be registered as a developer?
But I am really not sure as I don't develop add-ons myself.
Thanh Phan
Thank you
AnnaFrost2390
Thanks)
