Archicad C++ API
Can’t change the size of the drawing..
I am trying to change the size of my drawing. I am accessing the element’s bounds, (element.drawing.bounds) changing it and it doesn’t work..
I can change the name or position but bounds changes nothing..
Thanks in advance
4 REPLIES 4
Do you want to crop the drawing to a specified bounding box or change the sizing ratio of the drawing?
Ralph Wessel BArch
Central Innovation
I want to change the ratio, not to crop.. I guess that i miss some more properties that needs to be changed in order for this to work
Erenford
If you want to change the scale, change API_DrawingType::ratio (Magnification on Dialog). Note that the value is based on API_DrawingType::drawingScale (Original Scale on Dialog).
[API_DrawingType::ratio] = [API_DrawingType::drawingScale] / [your new Drawing Scale];
Ex.
If you want to change your 1:100 drawing to 1:200, you set ratio = 0.50. (50% on Dialog) // ratio = 100 / 200
For 1:100 -> 1:50, ratio = 2.0. (200% on Dialog) // ratio = 100 / 50
Thanks!
So I am able to change the ratio, but I want it to change to fit the grid cell. Do I need to change the bounds parameter?
Edit:
It seems that what I need to change is the bounds, but I can’t get it to be done in the actual drawing, just the variable. I am applying the changes with acapi_element_change (using a mask and memo) and the bounds aren’t changing on the drawing itself.. Thanks in advance.
Edit 2:
I have noticed that after changing the ratio the layout is “dead”. It doesn’t update anymore (even if I set manualupdate to false on the code and even if switching back to manual update and then again to auto).
It also doesn’t fit frame to drawing until I change it to manual resize and back to auto fit.
This is all in addition to my problem in edit 1, where the bounds aren’t changed on the actual draw.
I’m using ARCHICAD 21 update 7000..
Thanks
