Archicad C++ API
Cascading Menu
poco2013
Mentor
As a Newbie, I'm trying to create a sub-menu on the third level.
I'm OK with the first two levels, but can't figure out how to attach a sub menu to item 1A-A to create the third level per the attached image?
Gerry
1 REPLY 1
ReignBough
General wrote:
Cascading/hierarchic menu items
Use this item type if an Add-On needs more than one or two commands, or to organize the commands into a logical order. The number of items within the submenu is limited by OS constraints only. A single level of submenus is available only. Items of the submenus cannot be hierarchic.
~ReignBough~
ARCHICAD 26 INT (from AC18)
Windows 11 Pro, AMD Ryzen 7, 3.20GHz, 32.0GB RAM, 64-bit OS
