2004-11-16 05:13 AM - last edited on 2022-12-13 10:31 PM by Daniel Kassai
2004-12-02 09:24 AM
2004-12-02 10:01 PM
stefan wrote:I couldn't figure out from the website; you'll have to ask them whether they support CFM compilation on Mac OS X. (I think they only support Mach-O.)
Would this version also work?
2004-12-08 09:50 AM
Hello Stefan,
I can give you the details from the CodeWarrior side but you may need to get a little more clarification from Graphisoft.
CW Learning Edition does support CFM/Carbon development, so if that is all that is required you should be o.k. using it. However, LE4 is based upon CodeWarrior version 8. So if there was something specific that Graphisoft requires that was introduced in CW v9 then it wouldn't work.
So you may want to check with them and see if it is just the case that they tested with v9 and that is why they recommend it or whether there is a specific reason that they list version 9.
There is an academic version of CW 9 if needed. I believe it runs about $119.00 USD. Though it does provide a full version of CW 9 where LE4 is a restricted version.
And you may want to check on that as well. LE 4 will only output executables/applications. So if you are wanting to output Libraries, Code Resources or Plugins then you would need CW 9 Academic. Also, LE4 will only allow 32 files per project so if the SDK uses more there would be a problem.
So on second look, chances are that you will need CW v9 Academic.
I hope this helps.
Regards,
Jonathan
2004-12-09 10:15 AM
2004-12-13 08:41 PM
2004-12-14 01:18 AM
Oleg wrote:The professional (non-academic) EULA says that you can transfer the license if you transfer the original media and documentation and the other party agrees to the license terms. Did you mean the academic version, Oleg?
One more question about CodeWarrior.
What states the CW EULA about license transfer.
2004-12-14 08:22 AM
Karl wrote:Thank you Karl.
The professional (non-academic) EULA says that you can transfer the license if you transfer the original media and documentation and the other party agrees to the license terms. Did you mean the academic version, Oleg? Karl
