Archicad C++ API
Coloring Wall using C++ code
roni
I was trying to provide different colors to wall using the C++ API’s. Could someone help which property has to be used? I’m using ArchiCAD 25
Hi Roni,
There are a lot of different ways depending on the exact thing you want to do (everything related to API_WallType)
  • Change the building material: elem.wall.buildingMaterial
  • Override just on a surface: elem.wall.refMat/ elem.wall.sideMat/ elem.wall.oppMat
  • Change the color in 2D views: elem.wall.cutFillPenand/or elem.wall.cutFillBackgroundPen
Best,
Bernd
PS: Please post C++ questions into the section 'Developer Hub -> Archicad C++ API'.
Automating Archicad with Add-Ons, GDL-Objects & Python Archi-XT.com
Hi Bernd,
Thanks for the reply, I will be trying out what you have said above.
Also will be posting the questions to exact sections đŸ˜€
