ā2019-03-01
09:36 AM
ā2022-10-04
04:36 PM
Daniel Kassai
Solved! Go to Solution.
ā2019-03-02 09:24 AM
ā2019-03-02 01:21 AM
ā2019-03-05 12:08 PM
ā2019-08-06 04:06 AM
ā2019-08-06 02:01 PM
gavinNZz wrote:Could you clarify the context in which you would like to modify parameters, i.e. broadly the application within a specific workflow? That function will be applicable to many workflows, but not all.
Would this functionality you talk of work in the case of a live connection with the parameters of a selected object?
ā2019-08-07 12:13 AM
Ralph wrote:Basically when a custom object is selected at any point in a workflow it would, through an AC add-on, expose its parameters to a xml file which would be read and written to by the external software which in turn would feed updated parameters back into the XML and, through the AC add-on, the object would be updated.
ā2019-08-07 12:24 AM
ā2019-08-07 11:37 AM
Ralph wrote:Thanks Ralph, good to know, just have to learn C++ now......ummmmm.....might be sometime!
Yes, that should work. Use this in conjunction with notifications from ARCHICAD of a selection change (and possibly editing if relevant).
ā2019-08-07 12:00 PM
