Archicad C++ API
Communication Manager - saving as OBJ
First post on that Forum - hello everybody,
Problem: I'm developing a simple add-on. At some point it should save current project (3D data) in Wavefront OBJ format. There's already an add-on for writing out OBJ format, which works fine, so I should use it from my add-on.
Question: how do I know the MDID (module identifier) to properly call the third-party add-on from my add-on?
I know there's Communication Manager, and I've searched the docs and this forum. Looks like this should be pretty straightforward, yet: what is the OBJ add-on MDID?
In the doc's example they use DXF/DWG:
API_ModulID mdid = { 1198731108, 1322668197 }; // MDID of the DXF/DWG add-on
Again, how they know what is the mdid of that module? How to find it?
I'm rookie with ArchiCAD API - hope you guys can help!
10 REPLIES 10
I am trying to do the exact same thing..
Anyone knows how can I find the MDID?
Akos Somorjai
For the Wavefront add-on:
API_ModulID mdid = { 1198731108, 1142057562 };
so the code is something like this:
static void		Do_Save_ObjFile (void)
	IO::Location folderLoc;
	API_SpecFolderID specID = API_UserDocumentsFolderID;
	ACAPI_Environment (APIEnv_GetSpecFolderID, &specID, &folderLoc);
	IO::Name		objName ("ObjTest.obj");
	IO::Location	objFile (folderLoc, objName);
	if (!objFile.IsEmpty ()) {
		API_IOParams ioParams;
		ioParams.method = IO_SAVEAS3D;
		ioParams.refCon = 1;
		ioParams.fileLoc = &objFile;
		ioParams.saveFileIOName = &objName;
		ioParams.noDialog = true;
		GSHandle	parhdl = nullptr;
		GSErrCode	err = ACAPI_Goodies (APIAny_InitMDCLParameterListID, &parhdl);
		if (err == NoError) {
			if (AddParameterToCommandCall (parhdl, "ioParams", &ioParams)) {
				API_ModulID	mdid;
				BNZeroMemory (&mdid, sizeof (mdid));
				mdid.developerID = 1198731108;
				mdid.localID = 1142057562;
				ACAPI_Command_Call (&mdid, 'OBJO', 1, parhdl, nullptr, false);
			ACAPI_Goodies (APIAny_FreeMDCLParameterListID, &parhdl);
	return;
}		// Do_Save_ObjFile
Best, Akos
Akos thank you so much!
Thats very helpful!!
Have a great day
Hello again akos, I’m having trouble making that function work, I can’t find the AddParameterToCommandCall functio. What is it?
Tibor Lorantfy
Here is a possible implementation for AddParameterToCommandCall function:
bool	AddParameterToCommandCall (GSHandle& parhdl, const char* parname, API_IOParams* ptr)
	API_MDCLParameter	par;
	BNZeroMemory (&par, sizeof (par));
	par.name = parname;
	par.type = MDCLPar_pointer;
	par.ptr_par = (void*) ptr;
	return ACAPI_Goodies (APIAny_AddMDCLParameterID, parhdl, &par) == NoError;
I’m running the code and the archicad is crashing every time, says it’s ucrtbase.pdb error
Any ideas how to solve?
I also get this message
Akos Somorjai
The 3D window has to be active when you call this function.
Hope this helps, Akos
Yep I know, but it still crashes..
