‎2015-07-30
12:35 PM
‎2023-07-13
03:44 PM
Doreena Deng
ACAPI_LibPart_GetDetails(oldLibPartIdx, &detl); ... ACAPI_LibPart_SetDetails_ParamDef(&newLibPart, paramsHdl, &detl);EDIT (2015 Aug 24)
‎2015-10-02 01:23 PM
ReignBough wrote:Hi,
I am trying to create a library from an existing one. What I did was just get all the information from the "source" library then copy (and modify) them. I am able to do this but limited to some section. Based on the documentation, ACAPI_LibPart_GetSection() will return APIERR_BADPARS for pictures, macros, etc.
I also followed the example given at the documentation of ACAPI_LibPart_GetSectionList(), modify it so that I will create a "destination" library.
When I called ACAPI_LibPart_GetSection(), I got APIERR_BADPARS and APIERR_NOLIBSECT on some of the sections. This means that the list that I got form ACAPI_LibPart_GetSectionList() have a "non-existing" section; or (as I interpret it) the section exists but the sectionHdl and sectionStr are not valid.
So how am I to copy [, create, and/or modify] these sections:
Sections with APIERR_BADPARS:
* API_SectAncestors
* API_SectCalledMacros
* API_SectInfoGIF
Sections with APIERR_NOLIBSECT:
* API_SectMigrTable
* API_SectCust_Keywords ('KWRD', this section is part of the section list but not part of the definitions, #define API_Sect...)
* API_SectCopyright
EDIT
I am also unable to find how to set/get values for the LibPart:
* Details > Author (see EDIT (2015 Aug 24))
* Details > Compatibility Options... (see EDIT (2015 Aug 19))
EDIT (2015 Aug 19)
I am now able to copy "Details > Compatibility Options..." via:ACAPI_LibPart_GetDetails(oldLibPartIdx, &detl); ... ACAPI_LibPart_SetDetails_ParamDef(&newLibPart, paramsHdl, &detl);EDIT (2015 Aug 24)
Based on the binary data of the library, the "Details > Author" is part of the copyright section. But since there is an error, this is not saved. I also tried saving this binary data as GSHandle and call save section API, but still error.
‎2015-10-13 10:33 AM
Akos wrote:But you can modify them on the dialog and save it with the new copyright. So, I assume that these values can be copied and/or modified. Also, the "Author" of the libraries that I want to
Why would you like to copy an existing library part? The copyright section is there for a reason 🙂
‎2015-10-14 01:57 PM
ReignBough wrote:If you don't have to do it on the fly, then you can use the LP_XMLConverter tool for that (part of the Library Developer Kit, accessible from the same place where you got the API DevKit from).
I just want to make a copy of the libraries and modify the contents, like adding parameter. So instead of adding this parameter on multiple libraries one by one, I just need to do it through an add-on.
