Erenford
Creating 3D Document filtered with marquee
Greetings, I'm trying to replicate thru code the creation of 3D document from floor plan with a marquee filter like when you manually create a marquee then right-click New 3D Document from Floor Plan.
I've managed to create a 3D Document using ACAPI_Database (APIDb_NewDatabaseID) and setting its filter mode to API_FilterByMarqueeAndRules although I'm not sure where I would put the marquee data in API_DocumentFrom3DType.
I tried manually creating one, dump its values (whole API_DocumentFrom3DType structure), then create one thru code using the values of the manual one, but the output didn't have a marquee.
Any help? Where should I set the filter? Or is 3D document not supported yet?
0 Replies 0
