yahavsa
Creating an add on for both Windows and Mac machines
I created an add-on using VS2022 on Windows 11 OS. I obtained an .apx file and tried to use it on both Windows and Mac machines. It works fine on Windows, but on the Mac, I couldn't find a way to make it work. Even when I changed the extension to .bundle, it still didn't work.
What should I do to ensure the same add-on works on both Windows and Mac machines?
Thanks, all!
1 Solution
Viktor Kovacs
Short answer
You will need a Mac. You can find the setup instructions on the GitHub page I've linked.
Long answer
I don't know any solution that could cross-compile native C++ code from Windows to Mac.
A solution can be to set up a CI system (like GitHub actions) that builds your solution in the cloud both for Windows and Mac. The CMake template example does this, you can find the corresponding action here: https://github.com/GRAPHISOFT/archicad-addon-cmake/blob/master/.github/workflows/build.yml
Another challenge here is that on Mac you need to code sign and notarize your Add-On. For this you need an Apple Developer ID and set up the workflow. As far as I know you will need a Mac along the process.
Go to post
3 Replies 3
kovacsv
Add-Ons must be compiled separately for Windows and Mac. If you use platform independent code it should not be a problem, but the build should happen separately.
I recommend using the cmake template that is prepared for both platforms:
yahavsa
Thank you very much for the quick answer!
If I am currently working in VS2022 on a computer with a Windows 11 OS and want to release an add-on for Mac, do I actually need to work on another IDE? Is it possible to do this through a Windows computer? Is it possible to do this using VS2022? Do I need to download any software for this to work? I would appreciate a brief explanation of whether and how I can produce a Mac add-on from a Windows computer. Thanks again!
Viktor Kovacs
Short answer
Long answer
