on
2024-04-30
11:01 AM
- edited on
2026-02-12
09:35 AM
by
Daniel Kassai
The programming language of Archicad Add-Ons is C++, so you have to be familiar with this language to start.
Archicad is extensible in several ways: by creating new menu commands and dialogs, adding import-export functionalities, etc. The API itself is general purpose, so you can write various Add-Ons with the same Development Kit.
First things first, you will have to set up your development environment:
| Archicad Versions | Windows | MacOS |
| Archicad 23 | Visual Studio 2017 (v141 toolset) | Latest Xcode (deployment target macOS 10.12) |
| Archicad 24 | Visual Studio 2017 (v141 toolset) | Latest Xcode (deployment target macOS 10.13) |
| Archicad 25 | Visual Studio 2019 (v142 toolset) | Latest Xcode (deployment target macOS 10.15) |
| Archicad 26 | Visual Studio 2019 (v142 toolset) | Latest Xcode (deployment target macOS 10.15) |
| Archicad 27 | Visual Studio 2019 (v142 toolset) | Latest Xcode (deployment target macOS 10.15) |
| Archicad 28 | Visual Studio 2019 (v142 toolset) | Latest Xcode (deployment target macOS 13) |
| Archicad 29 | Visual Studio 2019 (v143 toolset) | Latest Xcode (deployment target macOS 15.1) |
After you have installed the Development Kit you will find three folders at the install location.
You could start with one of the example Add-Ons, but it’s much easier to start with the template available on GitHub. Download the Archicad Add-On template from here.
For further steps please check out this page: Getting started with Archicad Add-Ons | ARCHICAD API (graphisoft.com)
If you feel stuck, post your questions in the Developer Forum.
