2025-07-18 05:53 AM
Despite every effort made, I can't call OpeningLines correctly within the 3D script,
I've requested the values from the new DW_MVOSettings rather than the old LibraryGlobals13, I think I created the right Dictionaries at the parameters.
But as I request the Lines to be drawn, I get an error that says: Dictionary not initialized or invalid at line 72 at the macro's 3D script (OpeningLines).
What could be wrong?
I'm trying to push
dict MVODoorOpLineOptions
MVODoorOpLineOptions.symbol3D.swingOrientation = 0
success = LIBRARYGLOBAL ("DW_MVOSettings", "iDW3DLineOrient", requestValue)
if success > 0 then MVODoorOpLineOptions.symbol3D.swingOrientation = requestValue
MVODoorOpLineOptions.symbol3D.show = 0
success = LIBRARYGLOBAL ("DW_MVOSettings", "bDoor3DOpLine", requestValue)
if success > 0 then MVODoorOpLineOptions.symbol3D.show = requestValue
MVODoorOpLineOptions.symbol3D.typeOut = 0
success = LIBRARYGLOBAL ("DW_MVOSettings", "iDW3DOppositeSideOpLineType", requestValue)
if success > 0 then MVODoorOpLineOptions.symbol3D.typeOut = requestValue
MVODoorOpLineOptions.symbol3D.typeIn = 0
success = LIBRARYGLOBAL ("DW_MVOSettings", "iDW3DOpeningSideOpLineType", requestValue)
if success > 0 then MVODoorOpLineOptions.symbol3D.typeIn = requestValue
call "OpeningLines" parameters a = a,
b = b,
frameThickness = gs_leaf_thk,
iOpeningType = 4,
opLineOptions = MVODoorOpLineOptions2025-07-22 12:58 PM - edited 2025-07-22 12:59 PM
Here is my version of "GetDWOpLines.gsm" macro used in older doors/windows which I modified to be usable with both library types
But it is reading only the INT MVO for doors & windows. it can be modified further to be compatible with DACH/ USA and whatever different config of libpack is used.
2025-07-23
03:24 PM
- last edited on
2025-07-25
10:52 PM
by
I still wasn't able to get it to work, the requests seem to be doing right, I was able to print the captured values accordingly.
It's the Macro call that fails. Specifically at
The error itself happens in the macro script after the Dict is passed (as far as it seems) according to the warning:
2025-07-25 07:06 AM
I have also replaced the openinglines macro with the old one(renamed) in the object (from 26 in this scenario), sorry I did not clarify in the first place.
2026-05-18 07:42 PM
I got stuck in the same place as @vdentello, when I tried to call the macro through the dict (as it seems to be the way to do it).
Has anyone got any clues or workarounds?
2026-05-18 07:43 PM
i'm with a similar problem. No one knows how to fix this?
3 weeks ago
I feel like I should've gotten used to that but I still have faith (but not much) that'll be able to set door Opening lines before 2030.
I've set a reminder so I don't miss this unsolved post's second birthday next year.
3 weeks ago
Your code and the latest version of the macro shouldn't cause this error message.
Could there be multiple OpeningLines macros in your loaded libraries? When you Open Object by Subtype..., exact paths are shown in the dialog.
Try debugging the received dict in OpeningLines macro with prints.
