2018-11-13
07:35 PM
2022-10-05
01:31 PM
Daniel Kassai
GSErrCode ModifyZonePoz(const API_Guid &guid) { API_Element element; API_Element mask; GSErrCode err; BNZeroMemory(&element, sizeof(API_Element)); // AC17-AC22 element.header.index ACAPI_ELEMENT_MASK_CLEAR (mask); ACAPI_ELEMENT_MASK_SET (mask, API_ZoneType, pos); //ACAPI_ELEMENT_MASK_SET(mask, API_ZoneType, roomName); element.zone.pos.x = 5.0; element.zone.pos.y = 10.0; //CHCopyC ("test", element.zone.roomName); element.header.guid = guid; // в заголовок поместить Guid element.header.typeID = API_ZoneID; // обязательно ! err = ACAPI_Element_Change(&element, &mask, NULL, 0, true); WriteReport("ACAPI_Element_Change %ld", err); return err; }What threatens me if, instead of this function, I copy all the properties of the zone and change the memo, then create a new one? ACAPI_Element_Create?
Solved! Go to Solution.
2018-11-14 09:29 PM
GSErrCode ModifyZonePos (const API_Guid& guid, const API_Coord& newPos) { API_Element element; API_ElementMemo memo; GSErrCode err; BNZeroMemory (&element, sizeof (API_Element)); BNZeroMemory (&memo, sizeof (API_ElementMemo)); // get actual zone element.header.guid = guid; err = ACAPI_Element_Get (&element); if (err == NoError) err = ACAPI_Element_GetMemo (element.header.guid, &memo); if (err != NoError) return err; // modify pos and create a new zone element.zone.pos = newPos; err = ACAPI_Element_Create (&element, &memo); ACAPI_DisposeElemMemoHdls (&memo); // delete original zone API_Elem_Head** heads = (API_Elem_Head**) BMhAllClear (sizeof (API_Elem_Head)); (*heads).guid = guid; ACAPI_Element_Delete (heads, 1); BMhKill ((GSHandle*) &heads); return err; }
2018-11-15 04:55 PM
GSErrCode ModifyZonePos(const API_Guid& guid, const API_Coord& newPos) { API_Element element; API_ElementMemo memo; GSErrCode err; BNZeroMemory(&element, sizeof(API_Element)); BNZeroMemory(&memo, sizeof(API_ElementMemo)); // get actual zone element.header.guid = guid; err = ACAPI_Element_Get(&element); if (err == NoError) err = ACAPI_Element_GetMemo(element.header.guid, &memo); if (err != NoError) return err; // delete original zone, before create a new zone, if not want get alert API_Elem_Head** heads = (API_Elem_Head**)BMhAllClear(sizeof(API_Elem_Head)); (*heads)[0].guid = guid; // 0 -1 zones ACAPI_Element_Delete(heads, 1); BMhKill((GSHandle*)&heads); // modify pos and create a new zone element.zone.pos = newPos; err = ACAPI_Element_Create(&element, &memo); ACAPI_DisposeElemMemoHdls(&memo); return err; }
2018-11-15 06:11 PM
ufo_ru wrote:Please note that the parameters of ACAPI_Element_Delete will change in ARCHICAD 23, so you won't have to bother with pointers anymore:
considering my level of understanding of x2 pointers
// Before AC23: GSErrCode ACAPI_Element_Delete (API_Elem_Head **elemHead, Int32 nItem); // Since AC23: GSErrCode ACAPI_Element_Delete (const GS::Array<API_Guid>& elemGuids);The sample code in API23 will be much shorter:
GSErrCode ModifyZonePos(const API_Guid& guid, const API_Coord& newPos) { API_Element element = {}; API_ElementMemo memo = {}; GSErrCode err; // get actual zone element.header.guid = guid; err = ACAPI_Element_Get(&element); if (err == NoError) err = ACAPI_Element_GetMemo(element.header.guid, &memo); if (err != NoError) return err; // delete original zone ACAPI_Element_Delete({guid}); // modify pos and create a new zone element.zone.pos = newPos; err = ACAPI_Element_Create(&element, &memo); ACAPI_DisposeElemMemoHdls(&memo); return err; }
