ā2022-07-05 05:56 AM
Thank you for your time and attention. I am working on electrical layouts and the roofs for this residence are steep. I would like to have a better way to see it so I may edit. Please, I want to edit the electrical symbols, which are library objects, to do two things:
1. Include a 3D morph that I can see in the 3D window
2. Show the object's ID. I am going around it by adding a label later, yet it's another element to edit.
Again your time is very valuable and I appreciate your feedback. Best regards.
Solved! Go to Solution.
ā2022-07-12 11:27 AM
Just search here for "How do I learn GDL" and you will find plenty of post with suggestions.
ā2022-07-12 11:31 AM
Thank you Barry!
ā2022-07-12 01:11 PM
Good to know you were able to get the code to work, thanks for posting back.
