4 weeks ago
Hi everyone, you can check the orthogonality of objects using an Archicad label. Would it also be possible to build a label that checks the distance to the project origin? For example, whether a wall is located within 5mm accuracy from the project origin. This would allow finding inaccurately placed elements.
4 weeks ago
You can't place an autotext in the label to show coordinates but there is an object in the library that does this (display coordinates where you place it). unfortunately you can't make it associative.
More on this: https://community.graphisoft.com/t5/Project-data-BIM/Documenting-coordinates/td-p/396793
4 weeks ago - last edited 4 weeks ago
There is WALL_POSITION[], but that obviously only works for walls... I guess the positioning of other polyline elements works differently...
| AC22-29 AUS 3200 | Help Those Help You - Add a Signature |
| Self-taught, bend it till it breaks | Creating a Thread |
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
