Archicad C++ API
Font Index numbers
poco2013
Mentor
Wondering if there is a listing of the available Fonts in Archicad and their index number?
Gerry
Ralph Wessel
Mentor
I think you'll find the available fonts match those installed on your machine, so it will vary from on installation to another.
Consequently, I also suspect that the font indices won't necessarily be consistent either.
Ralph Wessel BArch
Active Thread Ltd
Ralph Wessel
Mentor
Ralph Wessel BArch
Active Thread Ltd
poco2013
Mentor
Bummer!!
Setting the font for text output requires a Font index number not a Font name.
So I guess i'll have to use the getattribute function to get the index first? - seems like a roundabout way?
Gerry
Ralph Wessel
Mentor
It's not so bad - you can use ACAPI_Attribute_Search to look up the font by name, which gives you just the attribute header (including the index) without loading the whole attribute.
Ralph Wessel BArch
Active Thread Ltd
