Display malfunction of Graphisoft ID dashboard
Learn more
Dominic Wyss
Textblock: Font type
Hi all,
I'm trying to create a multipurpose textblock function. Basically its working but I have trouble with setting correct font style and font face.
Any ideas why? AC finds no errors.
!-- Init
	_iPgNr = 0
	_iBkNr = 0
	p_to_m = GLOB_SCALE / 1000
!-- Syles
	define style{2} "globStyle" "Papyrus",       2.5 * p_to_m, 4
	define style{2} "S1"        "Arial",         1.0 * p_to_m, 0
	define style{2} "S2"        "Times",         1.5 * p_to_m, 1
	define style{2} "S3"        "Luminari",      4.0 * p_to_m, 0
	define style{2} "S4"        "Arial Black",   4.0 * p_to_m, 32
!-- Base
	hotspot2 0,0
!-- Setup _rt
	dict _rt
	_rt.x = 0.5
	_rt.y = 0.5
	_rt.anchor = 1
	_rt.align = 1
	_rt.style = "globStyle"
!-- First Block
	_rt.line[1].part[1].s = "S3"
	_rt.line[1].part[1].v = "Luminari normal "
	_rt.line[1].part[2].s = "S4"
	_rt.line[1].part[2].v = "Arial Black sup "
	_rt.line[1].part[3].s = "S3"
	_rt.line[1].part[3].v = "Luminari normal "
	_rt.line[1].part[4].s = "S4"
	_rt.line[1].part[4].v = "Arial Black sup"
	_rt.line[2].v = "Times bold"
	_rt.line[2].s = "S2"
	_rt.line[3].v = "Papyrus underline"
	!_rt.line[3].s = "S3" !-> use global style
	_rt.line[4].s = "S1"
	_rt.line[4].v = "Arial normal"
	_rt.line[5].part[1].s = "S1"
	_rt.line[5].part[1].v = ""
	_rt.line[5].part[2].s = "S2"
	_rt.line[5].part[2].v = "Times Bold"
	gosub "rtBlock"
	rect2 _rt.x, _rt.y, _rt.x + _rtWidth, _rt.y + (-1 * _rtHeight)
!-- Second Block
	add2 0,-1* (_rtHeight + 0.1)
	_rt.line[1].s = "S1"
	_rt.line[1].v = "Luminari normal"
	gosub "rtBlock"
end ! end ! end ! end ! end ! end ! end ! end ! end ! end ! end ! end ! end ! end ! end ! end ! end ! end ! end ! end !
"rtBlock":
! Mehrzeiliger Text als Richtext ausgeben.
! Es können mit .part[] pro Paragraph mehrere verschiedene Textstile gesetzt werden.
! Stift muss vor Aufruf gesetzt werden.
! Caller:
! _rt              - (dict)
!    .x            - (real)   x-Position des Richtextes
!    .y            - (real)   y-Position des Richtextes
!    .anchor       - (int)    Textanker
!    .align        - (int)    Ausrichtung der Paragraphen
!    .style        - (string) Style für alle einfachen Zeilen
!    .line      - (array)  Array mit Texten pro Zeile
! Responder:
! _rtHeight        - (real)   Textblock Höhe
! _rtWidth         - (real)   Textblock Breite
! Other:
! _iPgNr           - (int)   Paragraph-Index (am Anfang des Scipts initialisieren und auf 0 setzen)
! _iBkNr           - (int)   Block-Index (am Anfang des Scipts initialisieren und auf 0 setzen)
! Help:
! mögliche Struktur für _rt.line[]:
!    .line.s         - (string) Style (optional)
!    .line.v         - (string) Text
! oder:
!    .line.part.s - (string) Style
!    .line.part.v - (string) Text
!    * m darf aktuell maximal 4 sein! (weitere Teile werden ignoriert)
	__nLines = vardim1(_rt.line)
	for q = 1 to __nLines
		_iPgNr = _iPgNr+1
		put _iPgNr
		if haskey(_rt.line.v) then
			if haskey(_rt.line.s) then
				paragraph _iPgNr _rt.align, 0, 0, 0, 1
					style _rt.line.s
					_rt.line.v + "\ts = " + _rt.line.s
				endparagraph
			else
					_rt.line.v + "\tgs = " + _rt.style
				endparagraph
			endif
		else
			if haskey(_rt.line.part) then
				if vardim1(_rt.line.part) = 1 then
						style _rt.line.part[1].s : _rt.line.part[1].v
					endparagraph
				endif
				if vardim1(_rt.line.part) = 2 then
						style _rt.line.part[2].s : _rt.line.part[2].v
					endparagraph
				endif
				if vardim1(_rt.line.part) = 3 then
						style _rt.line.part[3].s : _rt.line.part[3].v
					endparagraph
				endif
				if vardim1(_rt.line.part) >= 4 then
						style _rt.line.part[4].s : _rt.line.part[4].v
					endparagraph
				endif
			else
				!style _rt.style
				"No Text to print!"
				endparagraph
			endif
		endif
	next q
	_iBkNr = _iBkNr+1
	__bkName = "bk" + str("%",_iPgNr)
	style _rt.style
	textblock_ __bkName 0, _rt.anchor, 0, 1, 1, 0, __nLines,
		get(__nLines)
	richtext2 _rt.x, _rt.y, __bkName
	_dummy = REQUEST ("TEXTBLOCK_INFO", __bkName, _rtWidth, _rtHeight)
	_dummy = removekey(_rt.line)
return
Thanks for any help
Dominic
AC27 CHE - macOS Ventura M1
Dominic Wyss
I did some testig and I think it's a general problem with paragraphs and different fonts.
I created a native text in ac with several lines and different fonts each line.
then saved as new object.
source code is as expected but representation is wrong.
paragraph
set style "style 1"
"text"
endparagraph
paragraph
set style "style 2"
"text"
endparagraph
What am I doing wrong?
Dominic
Peter Baksa
The problem is with font names, all used style's font names have to be correct.
In GDL the font names visible on the Archicad UI can't be used. REQUEST "FONTNAMES_LIST" returns a list of installed fonts.  "Arial" can be "Arial Western" or "Arial Central European", etc...
Péter Baksa
Software Engineer, Library
Graphisoft SE, Budapest
