Archicad C++ API
GDL help on Archicad Object in order to customise it
ape2000
Hi everyone
I am working on the collaboration template with Imperial college of London. Has anyone worked on this before? If not I would like to start this entry as a part of a series of posts where we talk about ICL collaboration.
The first issue I have come across is I have to line up the 'Revision History Detailed 25' with their existing title block. I guess I need to adjust the settings in the GLD object? I have managed to open the object and get parameters, am I in the right way?. Could someone experienced on GDL coding give me some hints?
Regards,
Javier
1 REPLY 1
Miha_M
Activating the standard Revision History Detailed library part gives you some editable hotspots. With this you can re-arrange the column width. No GDL coding needed.
| Archicad 4.55 - 27
