ā2014-01-15
04:45 PM
ā2023-08-01
04:36 PM
Doreena Deng
ā2014-01-15 10:12 PM
API_Element apiElement;
API_ElementMemo memo;
GSErrCode err;
//const API_Guid APIGuid;
BNZeroMemory (&element, sizeof (API_Element));
const GS::Guid GSGuid = element.GetElemGuid();
//&APIGuid = GSGuid2APIGuid ( &GSGuid);
err = ACAPI_Element_GetMemo(const API_Guid& GSGuid2APIGuid(&GSGuid), &memo);
if (err == NoError) {
ā2014-01-16 02:55 PM
GSErrCode PrintElementSurfaceAndVolume (const API_Guid& guid)
API_Quantity quantity, mask;
API_Quantities quantities;
API_QuantityPar params;
char s[256] = { '\0' };
GSErrCode err;
ACAPI_ELEMENT_QUANTITY_MASK_CLEAR (mask);
ACAPI_ELEMENT_QUANTITY_MASK_SET (mask, wall, surface1);
ACAPI_ELEMENT_QUANTITY_MASK_SET (mask, wall, surface2);
ACAPI_ELEMENT_QUANTITY_MASK_SET (mask, wall, volume);
// Check API_Quantity and API_WallQuantity in the documentation for other options to set!
quantities.quantityData = &quantity;
params.minOpeningSize = EPS;
err = ACAPI_Element_GetQuantities (guid, ¶ms, &quantities, &mask);
sprintf (s, "surface1: %.2lf surface2: %.2lf volume: %.2lf", quantity.wall.surface1, quantity.wall.surface2, quantity.wall.volume);
ACAPI_WriteReport (s, true);
return err;
// how to use this function:
ModelerAPI::Element element;
PrintElementSurfaceAndVolume (GSGuid2APIGuid (element.GetElemGuid ()));
ā2014-01-16 03:35 PM
// first you should get the model
ModelerAPI::Model model;
// then you can iterate through the elements, bodies and polygons of the model
Int32 iElement = 0, iBody = 0, iPgon = 0;
Int32 nBody = 0, nPoly = 0;
Int32 nElements = model->GetElementNum ();
ModelerAPI::Body body;
ModelerAPI::Polygon polygon;
for (iElement = 1; iElement <= nElements; iElement++) {
model->GetElement (iElement, &element);
nBody = element.GetBodyNum ();
for (iBody = 1; iBody <= nBody; iBody++) {
element.GetBody (iBody, &body);
nPoly = body.GetPolygonCount ();
for (iPgon = 1; iPgon <= nPoly; iPgon++) {
body.GetPolygon (iPgon, &polygon);
// now you can get the material of this polygon
ModelerAPI::Material material;
model->GetMaterial (polygon.GetMaterialIndex (), &material);
ModelerAPI::Color color = material.GetSurfaceColor ();
double alpha = material.GetTransparency ();
// check other available informations about the material in GSModelDevLib/ModelMaterial.hpp
} ā2014-01-16 05:32 PM
