GSModeler element to API_element
Hi All,
I have the GSModeler elements of a model, and I would like to get parameters from it. (material, volume, etc..). Could you please share a piece of code how can I get this through the API?
Thanks: Andor
4 Replies 4
This is the place I am stuck at. Overall am I heading to the right direction to get the wanted properties of the elements?
API_Element      apiElement;
	API_ElementMemo  memo;
	GSErrCode        err;
	//const API_Guid		 APIGuid;
	BNZeroMemory (&element, sizeof (API_Element));
	const GS::Guid GSGuid = element.GetElemGuid();
	//&APIGuid =  GSGuid2APIGuid ( &GSGuid);
	err = ACAPI_Element_GetMemo(const API_Guid&    GSGuid2APIGuid(&GSGuid), &memo);
	if (err == NoError) {
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
Szia Andor,
here is a short example code to get the volume and surface areas of an element:
GSErrCode PrintElementSurfaceAndVolume (const API_Guid& guid)
	API_Quantity      quantity, mask;
	API_Quantities    quantities;
	API_QuantityPar   params;
	char              s[256] = { '\0' };
	GSErrCode         err;
	ACAPI_ELEMENT_QUANTITY_MASK_CLEAR (mask);
	ACAPI_ELEMENT_QUANTITY_MASK_SET (mask, wall, surface1);
	ACAPI_ELEMENT_QUANTITY_MASK_SET (mask, wall, surface2);
	ACAPI_ELEMENT_QUANTITY_MASK_SET (mask, wall, volume);
	// Check API_Quantity and API_WallQuantity in the documentation for other options to set!
	quantities.quantityData = &quantity;
	params.minOpeningSize = EPS;
	err = ACAPI_Element_GetQuantities (guid, &params, &quantities, &mask);
	    sprintf (s, "surface1: %.2lf  surface2: %.2lf  volume: %.2lf", quantity.wall.surface1, quantity.wall.surface2, quantity.wall.volume);
	    ACAPI_WriteReport (s, true);
	return err;
// how to use this function:
ModelerAPI::Element element;
PrintElementSurfaceAndVolume (GSGuid2APIGuid (element.GetElemGuid ()));
Soon I will write an example for getting materials too.
Best Regards,
Tibor
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
Szia Andor,
to get the material informations of a GModeler element you should iterate through the polygons of the element.
// first you should get the model
	ModelerAPI::Model model;
// then you can iterate through the elements, bodies and polygons of the model
	Int32						iElement = 0, iBody = 0, iPgon = 0;
	Int32						nBody = 0, nPoly = 0;
	Int32						nElements = model->GetElementNum ();
	ModelerAPI::Body				body;
	ModelerAPI::Polygon			polygon;
	for (iElement = 1; iElement <= nElements; iElement++) {
		model->GetElement (iElement, &element);
		nBody = element.GetBodyNum ();
		for (iBody = 1; iBody <= nBody; iBody++) {
			element.GetBody (iBody, &body);
			nPoly = body.GetPolygonCount ();
			for (iPgon = 1; iPgon <= nPoly; iPgon++) {
				body.GetPolygon (iPgon, &polygon);
				// now you can get the material of this polygon
				ModelerAPI::Material material;
				model->GetMaterial (polygon.GetMaterialIndex (), &material);
				ModelerAPI::Color color = material.GetSurfaceColor ();
				double alpha = material.GetTransparency ();
				// check other available informations about the material in GSModelDevLib/ModelMaterial.hpp
Hope this helps!
Best Regards,
Tibor
Szia Tibor!
Thanks a lot
