Archicad C++ API
Get all doors on a zone. [RE-OPEN]
ReignBough
I am able to get the doors on a zone using ACAPI_Element_GetRelations(API_RoomRelation). But what I found out is that this is applicable to doors where its face/surface touches the edge of a zone.
I am having trouble now getting the doors where they are in the middle of two zones. (see attached image)
~ReignBough~
ARCHICAD 27 INT (since AC18)
Windows 11 Pro, AMD Ryzen 7, 3.20GHz, 32.0GB RAM, 64-bit OS
5 REPLIES 5
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
In API19 ACAPI_Element_GetRelations function is extended and you can call it for doors and windows also.
Example code:
API_Element			doorElement;
API_DoorRelation	doorInfo;
err = ACAPI_Element_GetRelations (doorElement.header.guid, API_ZombieElemID, &doorInfo);
if ((doorInfo.toRoom == myRoom1Element.header.guid && doorInfo.fromRoom == myRoom2Element.header.guid) ||
	(doorInfo.toRoom == myRoom2Element.header.guid && doorInfo.fromRoom == myRoom1Element.header.guid)) {
	// this door is in the middle of myRoom1Element and myRoom2Element
If you check this for each door then you can get all doors on the zone.
ReignBough
Thanks Tibor. I forgot to tell that I am currently working on AC17 but I will take note on this when I start the conversions.
~ReignBough~
ReignBough
I started converting my add-on to 18 and found out that the said API_DoorRelation structure does not exist.
~ReignBough~
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
I'm really sorry! It's my fault, unfortunately this new feature with this structure was implemented only in API19. So you have to wait for it few more month.
I updated my previous post.
