2016-02-12
09:08 AM
2023-07-12
09:11 PM
Doreena Deng
2016-02-19 10:54 AM
gehairing wrote:You could deduce this from the library part subtype,
i need to know what is exactly the library part.
(a stair, a window, a door, a wall...). [...] How can i find "element.header.typeID" and "element.header.variationID" from a API_LibPart ? I have the "API_LibTypeID" but this is not enough. By example, i can't know that a libpart is a "stair" by example.
2016-02-22 11:00 AM
GS::UniString s = libPart.ownUnID;
GS::Guid gs_guid(s);
API_Element element;
BNZeroMemory (&element, sizeof (API_Element));
element.header.guid = GSGuid2APIGuid (gs_guid);
GSErrCode err = ACAPI_Element_Get(&element);
if(err == NoError)
typeID = element.header.typeID;
variationID = element.header.variationID;
But because i don't really know what it means i can't say why it doesn't work 2016-02-22 01:02 PM
gehairing wrote:Library parts are organised in a hierarchical structure, so the 'subtype' of an object determines its parent and therefore its 'type'. If you refer to the attached image, you can see the ARCHICAD Subtype selection dialog with the Stairmaker subtype selected. This would make the object a type of 'Stair' (and also a type of 'Model Element').
Do you mean the ownUnID can give me an element from wich i can extract typeID and VariationID ?
2016-02-23 06:26 PM
2016-02-24 11:38 AM
gehairing wrote:For background information, look at the
Sorry, I don't understand how can i access the subType you talk about ?
