ā2004-05-12
09:53 AM
ā2022-12-13
10:00 PM
Daniel Kassai
ā2008-11-26 11:41 AM
ā2008-11-26 12:29 PM
ā2008-11-26 05:06 PM
atila-diffusion wrote:Yes, the examples default to creating the apx in the debug folder. Different project settings result in a release version. Just move the apx into your add-ons folder and restart AC, or load the apx using Options > Add-On Manager.
i forgot to say that i'm using Visual Studio 2008, but I think i found the solution.
When I launch the project , a folder named "debug" is created and it contains the .apx file.
Is this file I have to import in archicad?
I tried to use the helloWorld and to import it in archicad but it still not work, i have a message in the Extension Infos Box which says that the file is already not an extension or it's not updated for using with this version of archicad.
I tried with archicad 9, 10 and 12.
(sorry for my poor english)
ā2008-12-01 11:28 AM
ā2008-12-01 02:53 PM
atila-diffusion wrote:What did you use to build the Mac version?
I succeeded to build a Hello World Add-On thanks to your Blank Add On. this one works on windows but not on Mac is that normal? Should I do something to solve it?
ā2008-12-02 09:41 AM
ā2008-12-02 10:53 AM
atila-diffusion wrote:Yes, you need to use XCode on a Mac. Fortunately Apple provides a full development suite with the Mac OS (XCode, Interface Builder, etc), so it's quite easy to get started (provided you have a Mac).
I used Visual Studio 2008 to build the apx. Do I have to build differently the mac version from the windows version?
ā2008-12-02 11:33 AM
ā2008-12-02 02:28 PM
atila-diffusion wrote:Just one word of caution - if you want to compile on multiple platforms, you must stick to agreed standards. Microsoft is notorious for introducing subtle changes to standards (sometimes called "standards-poisoning") so that moving to another platform seems very difficult. It is very easy to produce cross-platform add-ons if you are aware of this issue from the start.
so i can write mon plugin on Visual studio and at the end i'll will build it With visual and with XCode.
ā2008-12-02 02:55 PM
