stefan
Getting Started with the API DevKit
I welcome this more open and friendly approach to independent developers, although I still have a few remarks: I started trying to write a simple plugin for Archicad and all I can say is that it stopped at trying. The plugin is compiled but not recognised by Archicad. And I can't seem to find out why.
I wonder if it would be possible to have a few ready-to-compile examples in the Devkit. The samples are not compiling either... and seem to be made for an older version of the DevKit. In fact, I think the resource compiler is crashing...
I'm sorry to say, but I made my first fully working AutoCAD ObjectARX-plugin after stepping through the included ARX-tutorials just half an hour after downloading the SDK. I can't say that about the Archicad DevKit.
I really hope that I can get it at least to work... I wonder why there is no open forum on Developments for Archicad. After all, it's what made AutoCAD and 3DStudio so popular.
Don't see my mail as completely negative. I see that Graphisoft is trying hard to open up the development for other interested parties (e.g. freelancers, academic research), but since I'm not a fully qualified programmer (I have an architectural degree, not a programming degree), it's hard to get started. It's not that I'm a total newbie, since I have written a few programs allready using C++, MFC and OpenGL, but at the moment it's not working either.
Archicad-user since 1998
my Archicad Book
29 Replies 29
Hello everyone,
I'm trying to test the examples which are in the dev kit, but I don't understand how to compile them.
How do you get an .apx file since the examples?
Thanks a lot
i forgot to say that i'm using Visual Studio 2008, but I think i found the solution.
When I launch the project , a folder named "debug" is created and it contains the .apx file.
Is this file I have to import in archicad?
I tried to use the helloWorld and to import it in archicad but it still not work, i have a message in the Extension Infos Box which says that the file is already not an extension or it's not updated for using with this version of archicad.
I tried with archicad 9, 10 and 12.
(sorry for my poor english)
Yes, the examples default to creating the apx in the debug folder. Different project settings result in a release version. Just move the apx into your add-ons folder and restart AC, or load the apx using Options > Add-On Manager.
The apx MUST be compiled with the matching dev kit for the version of AC which you want to test it with.
Further, to run sample apx - if you do not have a developer ID - you must run AC in Demo mode, not licensed mode.
I succeeded to build a Hello World Add-On thanks to your Blank Add On.
this one works on windows but not on Mac is that normal? Should I do something to solve it?
thanks a lot.
Ralph Wessel
I succeeded to build a Hello World Add-On thanks to your Blank Add On. this one works on windows but not on Mac is that normal? Should I do something to solve it?
What did you use to build the Mac version?
Ralph Wessel BArch
Central Innovation
I used Visual Studio 2008 to build the apx. Do I have to build differently the mac version from the windows version?
Ralph Wessel
Yes, you need to use XCode on a Mac. Fortunately Apple provides a full development suite with the Mac OS (XCode, Interface Builder, etc), so it's quite easy to get started (provided you have a Mac).
Ralph Wessel BArch
Central Innovation
Ok thank you,
so i can write mon plugin on Visual studio and at the end i'll will build it With visual and with XCode.
Thank a lot.
Ralph Wessel
Just one word of caution - if you want to compile on multiple platforms, you must stick to agreed standards. Microsoft is notorious for introducing subtle changes to standards (sometimes called "standards-poisoning") so that moving to another platform seems very difficult. It is very easy to produce cross-platform add-ons if you are aware of this issue from the start.
Ralph Wessel BArch
Central Innovation
OK,
A last question.
I aim to create a plugin wich load an external hotlinks Module and past it on the scene. Do you think it's difficult. I've seen the "ModulData Manager" but I don't know if that's what I need, I also tried the example of "Module data manager" but it is written for API 6.1 and I don't succeed to rebuild it for archicad 12 :s
this API is very interesting but, on my opinion, not enough easy to use and to understand when we get started.
