Hashable struct for the GS::HashTable<Key, Value>
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2021-10-14 09:30 AM
I need to create a struct that can be used as a Key in a hashtable.
So far I made this:
struct Item{
GS::UInt8 parentId;
GS::UInt8 itemId;
const GS::UInt8 hash = this->parentId + this->itemId;
GS::ULong Item::GenerateHashValue() {
return GS::GenerateHashValue(this->hash);
bool operator== (const Item& other) const {
return (this->parentId == other.parentId && this->itemId == other.itemId);
It gives me the error:
Does not have a GenerateHashValue member or non-member function. I am pretty sure I have GenerateHashValue.
Can you please point some directions on this matter?
Solved! Go to Solution.
- Labels:
Add-On (C++)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-10-14 06:57 PM - edited ‎2021-10-14 06:57 PM
Fast tests. Works for me. VisualStudio.
Using test is:
GS::HashTable<Item,int> table;
Item itm = { 10, 20 };
table.Add(itm, 2);
table[itm] = 3;
AC24 (you need const qualifier)
GS::ULong Item::GenerateHashValue() const
AC25 (dont have time to study it )
return GS::CalculateHashValue(this->hash);
And just reply. Are you shure to use summary Ids for hashe generation ?
May be beter like this:
return ((ULong) parentId << 8 ) | itemId;
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-10-14 10:03 AM
I know how to make it work with c++ standard std::unordered_map
struct Item
int parentId;
short itemId;
bool operator==(const Item &other) const
return (parentId == other.parentId && itemId == other.itemId);
template <>
struct std::hash<Item>
std::size_t operator()(const Item& k) const
return (k.itemId + k.parentId);
with the above struct I can use the following:
Item itm2 = { 10, 20 };
std::unordered_map<Item, int> hashMap;
hashMap[itm] = 10;
hashMap[itm2] = 30;
std::cout << hashMap[itm2] << std::endl;
Output will be 30.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-10-14 12:42 PM
I think you need to mplement the GenerateHashValue as non member function.
GS::ULong GenerateHashValue( const Item& item )
return GS::GenerateHashValue( item.parentId + item.itemId );
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-10-14
12:49 PM
‎2021-10-18
02:58 AM
And I guess there is other variant.
Inherit your Item from GS::Hashable and implement virtual member
virtual ULong GenerateHashValue (void) const = 0;
like this
struct Item : public GS::Hashable
virtual ULong GenerateHashValue (void) const { return this->hash; }
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-10-14 03:19 PM
It says it is already declared in the .obj file. GIS is my namespace.
Error LNK2005 "unsigned int __cdecl GIS::GenerateHashValue(struct GIS::Item const &)" (?GenerateHashValue@GIS@@YAIAEBUItem@1@@Z) already defined in AddOnMain.obj AddOn \polyGIS\Build\Source.obj
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-10-14 03:20 PM
I can't find the GS::Hashable class.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-10-14 05:07 PM
Sorry. I worked on old project and checked it for old API.
It seem GS::Hashable was before AC24 and implementation of the HashTable was changed.
I will try it for API 24 and 25 later.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-10-14 05:11 PM
I was looking at other data structures which work with the GS::hashTable, the GS::Pair<T1, T2>. It has an implementation of the GenerateHashValue() like you said.
//This is from the GS::Pair<>
template <class Type1, class Type2>
ULong GenerateHashValue (const Pair<Type1, Type2>& pair)
return GS::GenerateHashValue (pair.first, pair.second);
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Using test is:
table.Add(itm, 2);
table[itm] = 3;
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-10-14 07:02 PM
I was pretty sure that there will be no conflict. Now that I think more about it will not work. Your solution works for me too, I forgot about the const, it is the same behavior as with operator overriding. Thank you very much!
