Archicad C++ API
How To Fire Click Event from Push Button in Dialog
Please teach me.
How To Fire Click Event from Push Button in Dialog on C++ Code.
DG_Command ?
I give you an example of how I do it:
The header of your dialog class:
class ExampleDialog : public DG::ModalDialog,
    public DG::PanelObserver,
    public DG::ButtonItemObserver,
    public DG::CompoundItemObserver
public:
    ExampleDialog (GSResModule dialResModule);
    ~ExampleDialog ();
private:
    virtual void PanelOpened(const DG::PanelOpenEvent& ev) override;
    virtual void ButtonClicked(const DG::ButtonClickEvent& ev) override;
    static const short DIALOG_ID = 32530;
    enum
        ButtonID = 1, // Id from your .grc file
    DG::Button button_;
Cpp file :
ExampleDialog ::ExampleDialog (GSResModule dialResModule) :
    DG::ModalDialog(dialResModule, DIALOG_ID, dialResModule),
    button_(GetReference(), ButtonID),
    AttachToAllItems(*this);
void ExampleDialog ::ButtonClicked(const DG::ButtonClickEvent& ev)
If something is not clear ask questions, I will try to answer.
Miklos Vegh
You can't generate a click evet from the code. But if the click handling statements are in a standalone function, you can call that function in the ButtonClicked notification and anywhere else.
