Archicad C++ API
How are you supposed to set up column headers in ListBox.
I'm trying to make a ListBox that shows multiple columns. I can get that much working but I can only seem to put a header on the first column. Here's my code:
DGListSetHeaderItemCount(dialogID, ResultsList, 2);
DGListSetHeaderFlags(dialogID, ResultsList, true, false, false);
DGListSetHeaderItemFlags(dialogID, ResultsList, 1, DG_IS_LEFT|DG_IS_NOTRUNC, true);
DGListSetHeaderItemText(dialogID, ResultsList, 1, "Property");
DGListSetHeaderItemFlags(dialogID, ResultsList, 2, DG_IS_LEFT|DG_IS_NOTRUNC, true);
DGListSetHeaderItemText(dialogID, ResultsList, 2, "Value");
//set up the columns
w = DGListGetItemWidth(dialogID, ResultsList);
DGListSetTabFieldCount (dialogID, ResultsList, 2); //two columns in the data
DGListSetTabFieldData(dialogID, ResultsList, 1, 0, w/2-1, DG_IS_LEFT, DG_IS_NOTRUNC, true, true);
DGListSetTabFieldData(dialogID, ResultsList, 2, w/2, w, DG_IS_LEFT, DG_IS_NOTRUNC, false, true);
//some test data
DGListInsertItem (dialogID, ResultsList, DG_LIST_BOTTOM);
DGListSetItemText (dialogID, ResultsList, DG_LIST_BOTTOM, "testppty\ttestvalue");
I saw another post that suggested that you have to set the header size, eg
(DGListSetHeaderItemSize(dialogID, ResultsList, 1, 100);
but that doesn't seem to have any effect on the problem.
How do I get the header text on the second column to appear?
Have you tried setting the number of columns first and then applying the header?
Ralph Wessel BArch
Central Innovation
That fixed it thanks!
