Yeojin Hwang
How can I get to the Z coordinate of each vertex of a Multi-Plane Roof?
I want to get the Z coordinate of each vertex of a Multi-Plane Roof.
Currently, I can get the X and Y coordinates via COORD in Element_memo, but I don't know how to get the Z coordinate.
I would appreciate any help you can give me.
I use Archicad 27 API
Jeff Thompson
See my images below for instructions.  If you're not seeing the z coordinates when left clicking or selecting ther point, check your Options/Work Environment.../Tracker and Coordinate Input.  Make sure the Show Z Coordinate is checked.
Select the point in which you want to view the Z coordinate.  It should show up in the XYZ Tracker next to your cursor.  If you're still not seeing the Z coordinate, try and using the Tab key on the keyboard after you select the point.
Let me know if this helps you out.
Project Manager
Rutledge Maul Architects, PS Inc., Seattle, WA
Windows 11 Pro, HP Pavilion Gaming Desktop 790, Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz 3.19 GHz, 32.0 GB RAM, 64-bit operating system.
Archicad 28 - Graphisoft Forward
Yeojin Hwang
Hi. Thanks for your answer.
I am writing an addon that outputs the coordinates of elements from the Archicad API,
I meant to ask how to write the source of the addon so that I can get the Z coordinate of each vertex of a Multi-Plane Roof.
