Archicad C++ API
How can I obtain data from the work scheme?
luna
I am currently working on plugin development for ARCHICAD, I want to obtain some data for the current project from the worksheet created by the user.
Can you provide some suggestions on which API to use?
A more detailed version would be better. ^^
Thank you. ^^
2 ACCEPTED SOLUTIONS
scottjm
I am by no means an API expert, but I am led to believe there are no API functions for the interactive schedule.
More than happy to be proven wrong though. 🤞
That sounds correct to me.
Schedules just gather information from the model, so the API will need to do the same.
Get it from the model and not the schedules.
8 REPLIES 8
scottjm
lol
That not very good, ty. ^^
Yes, I think there's a problem with my thinking.
Thank you.
i had to do the same: implement my own version of the schedules. that really sucks since there has to go a lot of development time in to that. but on the other hand it allows you to implement a schedule version that suits you're use case the best. i built a add-on for quantification for a construction administration programm. i added a selection management like solibri, that you can add properties and other stuff: so good thing is, you can develop a schedule system that suits your requirements bestwise 🙂
some tipps i wished i knew before:
1. api calls are costly, how ever you plan to implement your schedules, you have to outline your architecture that you do as less as possible api calls.
the answers from @BerndSchwarzenbacher in this post: https://community.graphisoft.com/t5/Developer-forum/Fastest-way-to-query-Database-for-specific-User-... helped me a lot.
2. the api error codes are somethimes hard to get something meaningfull out of them. best way is to take a call that works and customizing untill you break it and never go full in.
hope that helps a little..
wow:)
The functions I need to implement are very similar to yours. hah
The information you provided is very rich, and I need to spend some time thinking and testing.
If possible, I would like to keep in touch with you because I have just started developing ARCHICAD Add-On.
Because I have just started developing the ARCHICAD plugin, I am not sure how to implement the desired functionality now, I am just doing some testing to Get properties. xD
Thank you.
This is very helpful 🙂
im allways glad if i can help 😃
thats the right way!  do some testing until you get the hang of it. little step by little step.  😃
and don't forget to take a close look on the properties example solution from the development kit. and be advised: important property quantification stuff is not in the properties example but in the element example:
i found that uncool... xD
Thank you for taking the time. Joel.
Your example inspired me.
Best wishes,
Allen
