Archicad C++ API
How do I change the group of an element?
Hi. I'm developing an Archicad add-on that is supposed to automatically change values and coordinates in a plan. At a certain point I have to change data inside a text object which is member of a group. Since the content field can't be changed while the object is in a group, the element must first get out of the group, apply the changes and then get back in. I keep getting the APIERR_BADPARS error from ACAPI_Element_Change function. The code goes like this:
... //element processing
long g=0;
g=elem.header.groupId;
ACAPI_ELEMENT_MASK_CLEAR (mask);
ACAPI_ELEMENT_MASK_SET (mask, API_TextType, head);
elem.text.head.groupId=0;
err = ACAPI_Element_Change (&elem, &mask, NULL, 0, true);
... // text object content change based on ACAPI_Goodies - APIAny_ChangeContentID. This works fine on non-grouped text elements.
elem.text.head.groupId=g;
The code above lies within an undo session.
I cant' figure out the trick, so .. any help would be apreciated.
1 REPLY 1
Marius,
I haven't studied the rest of your code yet, but would it solve your problem if you simply suspended groups (see APITool_SuspendGroups) while you do this?
Ralph Wessel BArch
Central Innovation
