Archicad C++ API
How is two points perspective GetPerspectiveData() FOV working?
Hello. In 3D/All in general perspective
const PERSDEF& GetPerspectiveData () const;()
is sending different fov for general perspective and 2 points-perspective. Is this intended? In Corona, we were using this data for rendering, but we had a big FOV jump for general perspective and 2 points perspective renders.
We are using another formula and now our renders are the same as Cine4d renders. I'm just curious if it's an issue or it's intended. Thanks.
Akos Somorjai
Hi Alex,
This is intentional to produce the correct result for 2-point perspective we have to adjust the FOV.
Best, Akos
1 REPLY 1
Akos Somorjai
Hi Alex,
Best, Akos
