How to Obtain Bounding Box of Dimension Text in Archicad API
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2024-01-15
02:36 AM
2024-09-16
02:44 PM
Doreena Deng
I am currently working on a project using the Archicad API and I've encountered a challenge regarding dimension elements. Specifically, I am looking to obtain the bounding box for individual dimension texts.
So far, I have been successful in extracting various properties of dimension elements, such as the GUID, associated element GUID, text content, length, and position. However, I am unable to find a way to determine the bounding box for each dimension text.
Here is a snippet of my current approach:
void ReportDimensionElementProperties(const API_Guid& elementGuid, API_ElemTypeID elemType, std::ofstream& outFile) {
char reportStr[1024];
API_Element element;
BNZeroMemory(&element, sizeof(API_Element));
element.header.guid = elementGuid;
GSErrCode err = ACAPI_Element_Get(&element);
if (err == NoError && elemType == API_DimensionID) {
API_ElementMemo memo;
BNZeroMemory(&memo, sizeof(API_ElementMemo));
double totalLength = 0.0; // Variable to accumulate total length
if (ACAPI_Element_GetMemo(element.header.guid, &memo) == NoError) {
Int32 numDimElems = BMGetHandleSize((GSHandle)memo.dimElems) / sizeof(API_DimElem);
for (Int32 i = 0; i < numDimElems; ++i) {
API_DimElem& dimElem = (*memo.dimElems)[i];
API_Base base = reinterpret_cast<API_Base&>(dimElem.base);
totalLength += dimElem.dimVal; // Accumulate the length
// Extracting Dimension Text
GS::UniString dimText = (dimElem.note.contentUStr != nullptr) ?
*(dimElem.note.contentUStr) :
GS::UniString(dimElem.note.content);
// Formatting the output string for each dimension element
sprintf(reportStr, "Dimension element [%d], GUID: %s, Associated Element GUID: %s, Text: %s, Length: %.2f mm, Position: (%.2f, %.2f)",
i,
APIGuidToString(elementGuid).ToCStr().Get(),
APIGuidToString(base.guid).ToCStr().Get(),
dimText.ToCStr().Get(),
dimElem.dimVal,
dimElem.pos.x, dimElem.pos.y);
outFile << reportStr << std::endl;
// Retrieve and report the bounding box for the entire dimension element
API_Box3D boundingBox;
if (ACAPI_Element_CalcBounds(&element.header, &boundingBox) == NoError) {
sprintf(reportStr, "Linear Dimension Element, GUID: %s, Bounding Box: [(%.2f, %.2f, %.2f), (%.2f, %.2f, %.2f)], Total Length : % .2f mm",
boundingBox.xMin, boundingBox.yMin, boundingBox.zMin,
boundingBox.xMax, boundingBox.yMax, boundingBox.zMax,
totalLength); // Include total length here
else {
// Handle error in retrieving the bounding box
sprintf(reportStr, "Bounding Box for Dimension Element, GUID: %s: Not available",
APIGuidToString(elementGuid).ToCStr().Get());
ACAPI_DisposeElemMemoHdls(&memo);
else {
strcat(reportStr, "Error retrieving element memo");
else {
strcat(reportStr, "Error or Unsupported Element Type");
My question is: Is there a method or property in the Archicad API that allows access to the bounding box of individual dimension texts? If so, could you provide some guidance or examples on how to implement this?
Any insights or suggestions on this matter would be greatly appreciated.
Thank you in advance for your assistance.
