nishida_jp
How to Optimize Performance for Handling Large Data with Archicad's C++ API
When handling large amounts of data with Archicad's C++ API, the processing time is too long. What techniques can be used to process data more quickly?
For example, is multitasking possible? Please share any effective methods.
1 Reply 1
Ralph Wessel
It's possible to run concurrent processes in an add-on, but with significant restrictions. My general advice is:
  • Never call any API functions from any thread apart from the one the add-on is invoked on, i.e. don't use the API functionality concurrently. I can't rule out some functions being safe (only GS could advise on that) but assume they are not thread-safe
  • Don't try to run a process independent of invocation from Archicad, i.e. don't have something continuously as a child process of Archicad but running independently.
Some possible uses might include data-crunching once the requisite data has been obtained from the API - you could break the data into chunks and fire off multiple threads to process the chunks in parallel. But this would be started by a call from Archicad into the add-on, and this call should not return until all the threads are finished.
Take this as general advice rather than a completely definitive answer - GS might be able to provide some exceptions. But I expect this will generally set you on the right path.
Ralph Wessel BArch
Central Innovation
