How to add new Icon button?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2024-10-07 11:25 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2024-10-08 03:04 PM
You need something like this in your Palette/Dialog resource.
/* [ 3] */ IconButton 216 8 24 24 10002
The last number is the resource number for the icon which is typically specified in the fixed resource file (RFIX/AddOnFix.grc in a lot of templates).
For example:
#include "ResourceMDIDIds.hpp"
'MDID' 32500 "Add-On Identifier" {
AC_MDID_DEV /* Developer id. */
AC_MDID_LOC /* Add-On local id. */
'GICN' 10002 "SettingsIcon" {
"SettingsIcon"
If you use the Dialog Manager in C++ style, then you'll need DG::IconButton in your code.
Hope that helps
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2024-10-09 07:37 AM
Put your image in RFIX/Images folder.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2024-10-08 03:04 PM
For example:
"SettingsIcon"
Hope that helps
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2024-10-09 04:47 AM
How do I get the image?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2024-10-09 07:37 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2024-10-09 09:17 AM
For example 32612 is for my settings icon and I want to add a refresh icon. How do I get it's number? And do any image in the internet is applicable?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2024-10-16 10:50 AM
HI, you can use arbitrary icon identifier as you like, what matters is that it must be unique in your add-on resource (and must be a positive value in the signed short value range also (eg < 32768)).
How to create image file
You should create a .svg image. This way your icon will be correctly scaled according to the display scale factor. The svg file name must follow a special naming convention. For example in your case if you want an 18x18 pixel size icon it should be 'Refresh_18x18.svg'. Here the name is 'Refresh' and the _18x18 is added to it for the resource compiler system to handle it correctly. Obviously an other icon with size 32x24 would be OtherIcon_32x24.svg and so on.
The svg file can be prepared with Inkscape or an other svg-capable application. Inkscape is freely usable. If you use it there are some rules when drawing AC icons, some of them:
- Use pixels as unit
- Do not add pixmaps on the svg canvas
- Save your image with the 'Save As.../Optimized svg' menu command
Place image to the add-on resource
In the grc file the .svg and the image size extension is omitted, so add the icon name only as mentioned above:
"RefreshIcon"
You can load this image to the IconButton either in the resource as a previous comment shows, or you can instantiate a DG::Icon object and set it to a button or an other control.
DG::Icon refreshIcon (resourceModule, 10002);
button.SetIcon (refreshIcon);
