garry
datasmith export source code
Hi, folks
I want to export datasmith from archicad using source code, not UnrealDatasmithExporter
The googling result shows the only 2 similar projects:
- blender datasmith export project
- archicard dotbim export project
Could you help me?
I hope your experience and source code or links.
Thanks in advanced.
Hiromichi Shinkawa
Hi, I'm afriad we cannot provide you the source code as we're not the original developer of datasmith. Thanks!
Lingwisyer
Guru
You would be better off asking over on the Epic / UE forums for all things udatasmith as it is their file format and the pipeline they are pushing. Also, "export using source code" makes no sense... I assume you are wanting a raw geometry conversion? This will need to be clarified, again, over on the Epic / UE forums.
