Archicad C++ API
How to change extrusion surface in beam
Hello.
How do I change the Extrusion Surface of an Override Surface in Beam?
The property values of Top, left side, right side, bottom, and ends exist in memo.beamSegment, but I can't find the property values for extrusion surface.
Extrusion surface exists only in Circular and Complex profile, but I don't know how to change it.
When I change the Extrusion surface option in Archicad, leftMaterial is changed in code.
But if I change leftMaterial through code, there is no change in Extrusion Surface.
0 REPLIES 0
