‎2018-03-16
04:47 AM
‎2022-12-06
01:44 PM
Daniel Kassai
const GS::UniString a = L"xxx";or
DGTreeViewSetItemText(dialogID, itemID, CS,L"xxx");It is no problem if I develop in windows
‎2018-03-16 12:21 PM
GS::UniString a(u8"xxx", CC_UTF8);
‎2018-03-26 02:29 PM
#ifndef SL
std::string ToUtf8(const std::wstring& widestring)
size_t widesize = widestring.length();
if (sizeof(wchar_t) == 2)
size_t utf8size = 3 * widesize + 1;
char* utf8stringnative = new char[utf8size];
const UTF16* sourcestart =
reinterpret_cast<const UTF16*>(widestring.c_str());
const UTF16* sourceend = sourcestart + widesize;
UTF8* targetstart = reinterpret_cast<UTF8*>(utf8stringnative);
UTF8* targetend = targetstart + utf8size;
ConversionResult res = ConvertUTF16toUTF8
(&sourcestart, sourceend, &targetstart, targetend, strictConversion);
if (res != conversionOK)
delete [] utf8stringnative;
throw std::exception("La falla!");
*targetstart = 0;
std::string resultstring(utf8stringnative);
return resultstring;
else if (sizeof(wchar_t) == 4)
size_t utf8size = 4 * widesize + 1;
const UTF32* sourcestart =
reinterpret_cast<const UTF32*>(widestring.c_str());
const UTF32* sourceend = sourcestart + widesize;
ConversionResult res = ConvertUTF32toUTF8
*targetstart = 0;
else
return "";
#ifdef _WIN32
#define SL(str) str
#else
#define SL(str) ToUtf8(str).c_str()
#endif
#endif
const GS::UniString a = SL(L"xxx"); // This will compile well now.
You may move the code into a separate header file and include it everywhere you want to initialize UniString with a string literal. Just remove the last line with a comment.#include "sl.h" const GS::UniString a = SL(L"xxx"); // This will compile well now.
‎2018-03-26 07:25 PM
chebum wrote:A few observations:
UniString is implemented differently on Mac: it stores characters in UTF-8 encoding on Mac(e.g. 1-byte per character). On Windows it uses wchar_t which is 2-bytes per character. Thus const GS::UniString a = L"xxx"; will compile on Windows, but will fail on Mac. Graphisoft changed implementation of UniString somewhere between AC15 and AC21. In older versions it used wchart_t.
All C strings (char *, char []) are now UTF-8 encoded.2) Text encoding is not the same as the number of bytes consumed by a character. Many different encodings will use the same number of bytes, but are not equivalent. Constructing a UniString from wchar_t only works on Windows because it's commonly assumed to be UTF-16. It's a bad idea if you intend to write cross-platform code.
chebum wrote:I'd strongly recommend using the mechanisms provided by GS. Writing your own methods for solved problems just wastes time and opens you up to more bugs and future migration problems.#include "sl.h" const GS::UniString a = SL(L"xxx"); // This will compile well now.
‎2023-01-12 09:03 PM
Ralph, your expression throws me in an "Excess elements in scalar initializer" error.
Knowing that I am not familiar with the ACAPI expressions, can you tell me what am I doing wrong?
Thank you
Nic
