Andor Kocsis
How to set GDL parameter from addon?
Hi!
It will be great to find an example of how to set GDL's parameter from the addon. If there is an example in the SDK's "Examples" folder, I cannot identify which one. Could someone help me out, please?
Thx,
1 Solution
blackd3er77
You can take a look at the "Element_Test" example, maybe with the below command. The stair and railing parts are GDL objects.
Go to post
3 Replies 3
blackd3er77
Andor Kocsis
Yep, I found ACAPI_Element_ChangeParameters() there, thx.
blackd3er77
So glad when you can solve your issue.
