2021-09-06 06:01 PM
Hi!
It will be great to find an example of how to set GDL's parameter from the addon. If there is an example in the SDK's "Examples" folder, I cannot identify which one. Could someone help me out, please?
Thx,
Solved! Go to Solution.
2021-09-07 11:57 AM - edited 2021-09-07 12:28 PM
You can take a look at the "Element_Test" example, maybe with the below command. The stair and railing parts are GDL objects.
2021-09-07 12:09 PM
Yep, I found ACAPI_Element_ChangeParameters() there, thx.
2021-09-07 12:10 PM
So glad when you can solve your issue.
