Tran Thanh Lo
How to set a string for a cell in array values of GDL object?
Spoiler
I get and set a value in array values like this.
if ((*memo.params)[i].name == (GS::UniString)"matrix_area")
			API_AddParType* pAddPar = &(*memo.params)[i];
			GS::uchar_t** arrHdl = reinterpret_cast<GS::uchar_t**>(pAddPar->value.array);
			(*arrHdl)[0] = 'f';
But I can only set it to the uchar_t value. Can I set it a string value?
Can you answer for me? Thank you very much.
1 Solution
DGSketcher
Legend
In GDL land an array may only contain one data type e.g. number or string, they can't be mixed. Not sure if that is what you are trying to do?
Go to post
3 Replies 3
DGSketcher
Legend
Tran Thanh Lo
Yes, I see. Thank you very much.
You need to use something like GS::ucscpy to copy a whole string (instead of a single character) into a uchar_t pointer. And the handle needs to be appropriately sized!
Here's some (untested) sample code:
GS::Array<GS::UniString> stringsToCopy{ "foo", "barbar" };
// assuming we have a one dimensional parameter array of strings
auto& currentParam = (*memo.params)[i];
if (currentParam.dim1 != 1) { return; }
currentParam.dim1 = usedZoneCats.GetSize ();
currentParam.dim2 = 1;
GS::USize totalLength = 0;
for (const auto str : stringsToCopy) {
	// +1 because the "\0" string delimiter is not counted in GetLength () function
	totalLength += str.GetLength () + 1;
currentParam.value.array = BMReallocHandle (currentParam.value.array,
	totalLength * sizeof (GS::uchar_t), REALLOC_FULLCLEAR, 0);
auto attrArray = reinterpret_cast<GS::uchar_t*>(*currentParam.value.array);
GS::USize strStart = 0;
for (Int32 j = 0; j < currentParam.dim1; ++j) {
	GS::ucscpy (attrArray + strStart, stringsToCopy[j].ToUStr ());
	strStart += stringsToCopy[j].GetLength () + 1;
Automating Archicad with Add-Ons, GDL-Objects & Python Archi-XT.com
