Lachlan Green
Scheduling BMat info used in a Custom Profile
At the moment, I think this is just outside what is possible and I wanted to check I haven't missed something before going off on an alternate solution.  I want to schedule the ID, name and description of the BMat used in a Custom Profile, referenced by an object.
Getting the object to request the BMat Name, ID and description of the BMat used in the Custom Profile is simple enough. In this workflow there would only ever be one BMat in the profile.
Spoiler
n = REQUEST ("Profile_component_info", profile_parameter, 1, "gs_profile_bmat", bmat_index)
n = REQUEST("NAME_OF_BUILDING_MATERIAL", bmat_index, bmat_name)
n = REQUEST{2} ("BUILDING_MATERIAL_INFO", bmat_index, "gs_bmat_id", bmat_id)
n = REQUEST{2} ("BUILDING_MATERIAL_INFO", bmat_index, "gs_bmat_description", bmat_description)
However, I need to push these into parameters so they can be scheduled.  Which has to be done in either the Master or Parameter script.  Yet the "PROFILE_COMPONENT_INFO" can't be used in either Master or Parameter script.  "Expression returns 0 and contains dummy return values (empty string or 0) if used in parameter script, causing additional warning."
The only way around that I see is putting the required data into the Profile name and using characters to identify where to strip the different pieces of data. e.g. Code | Name | Description.  Not the worst thing in the world but less than ideal.
EDIT:  Ok scratch that.  We can't request the name of the profile in the Master or Parameter script either...  So close and yet so impossibly far.  Properties can't access the profile or building materials.  The whole workflow doesn't work and it has to go back to calling objects with 2D Symbol fragments.
Lachlan Green | Wilson Architects | BIM Manager, Architect
Started on AC9 | Currently AC28 & AC29 | BIMCloud | GDL
Mac Studio (14,13) M2 Max, 64GB, 1TB SSD | MacOS 15.7
Pertti Paasky
Obviously you can write text to a textfile from within UI-program.
The object needs parameters "CustomProfile" as the custom profile, on-off parameter "writeBM" for writing values to file named "BMfilename"
and  "folderpath" . You can separate different objects by glob_id.
Write this in UI-program: (PC-version)
n = REQUEST{4}("PROFILE_COMPONENT_INFO", CustomProfile, 1, "gs_profile_bmat", buildingmat1)
r = REQUEST{2} ("Building_Material_info", buildingmat1, "gs_bmat_surface", bmsurface1)
m = REQUEST ("Name_of_material", bmsurface1, name1)
if writeBM then
linecont=1
chout1=OPEN("text",folderpath+BMfilename+".txt","SEPARATOR='\t ' ,MODE=WA, fullpath")
output chout1, linecont, 1, glob_ID,CustomProfile,buildingmat1,bmsurface1,name1
close chout1
endif
- AC-24 FIN - WIN 10 - HP Zbook -
“A winner is just a loser who tried one more time.”
George M. Moore, Jr.
