Archicad C++ API
How to set properties value(type is numeric )
magicliang
Hello everyone, I'm currently trying to change properties, the properties type is numeric array , how can do it?
Thx for any help
Kind Regards
MagicLiang
ReignBough
You can set it in the main Parameters window.
~ReignBough~
ARCHICAD 27 INT (since AC18)
Windows 11 Pro, AMD Ryzen 7, 3.20GHz, 32.0GB RAM, 64-bit OS
In that dialogue you show, select the array field you want to change and then change the value that shows to the right.
