Archicad C++ API
How to skip "Active Library Usage" pop-ups without user intervention
sxs
Hi everyone:
  I want to make an automatic plugin,but the  "Active Library Usage" pop-ups blocks my process.
  How to skip it.
  eg:
Are you calling ACAPI_ProjectOperation_Open in this automation process? If so, try changing the value of useStoredLib in the API_FileOpenPars parameter passed to the function.
Ralph Wessel BArch
Central Innovation
4 REPLIES 4
Ralph Wessel BArch
Central Innovation
I open file like this怂Inspired by you, I already know how to do it ,thank you.
Can this be achieved through command-line arguments?
I don't know, but I doubt this is possible
Ralph Wessel BArch
Central Innovation
