How to update Drawing?
I want to save layoutbook as pdf after updating drawing that connected viewmap.
But, drawing is not update when I change window to layoutbook using APIDo_ChangeWindowID.
I get API_Element using API_DrawingID and change that.
Drawing is changed, but they are not updated.
Please let me know how to update drawing in layoutbook.
4 Replies 4
From what I understand this isn’t possible via API
I tried everything, including refreshing the dB and asking here. It seems to be impossible..
Thank you for the reply.
I solved this problem by waiting for the automatic update from ArchiCAD through a timer.
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
In API_DrawingType structure there is a member named manualUpdate.
If you set that member to false (and change the drawing by using ACAPI_Element_Change), then the drawing will be automatically updated by Archicad.
Using APIDb_CheckDrawingStatusID you can check the status of the drawing. If it says the drawing is not up-to-date yet, then you can wait until the APIDb_CheckDrawingStatusID says it was updated.
Hi Tomer thanks for the help, was looking for similar solution.
Regards,
Kevin J. Hodge
